Engine/Transmission (1994 - 1998) Boost Q???
Engine/Transmission (1998.5 - 2002) vacuum pump seal
2nd Gen Non-Engine/Transmission How much room?
ok now that i have the 370 in when i punch it the boost guage goes to like 35 but my guage only goes to that and thats at like 2000 rpms is that ok or will i break or blow the head gasket or somethin can i runn it to 2500 any info will help Thanx
Russell:D
Russell with your 215 pump you probably more like 40 psi, the main issue is that is past were the turbo is efficient, BOTW about . 060 forward from the center is optimal for a #10;)
Save up for an HX40 or B-1.
Jim
No, you should not blow a head gasket. I have been running 38-40 psi on my stock head gasket with no issues and have asked the same question before. There are guys on here running in the 50 psi range with the stock head gasket and have had no issues.
