Bosch 370 Diamond B inj
2001 owners READ THIS....LONG
year 1999 mods whats best bang for the $$$
Gentlemen. I have a slightly bombed 95 Ram(see signature) What could I expect in the way of performance if I install a set of Bosch 370 Diamond B injectors? I intend to install a 4" exh in the next few days. thanks for the input.
I talked to piers yesterday about how my pump would handle them.
here is what he wrote:
"Your pump will run the 370's, but with a bit of a stumble in the
1100-1200rpm range. The high flow delivery valve kit [$225. 00] will eliminate most of this. "
"To get much more fuel out of your pump I would suggest the hi flow delivery valve kit & the governor kit. "
Thanks, Piers
I have pritty much the same setup as you so this will apply to you also.
I know that it is not an answer to your question, but it is more food for thought.
I have a question to add to this which might help you also:
Has anyone ran the 370s with the 160 pump with a plate in it and no hi flow DV, if so How bad was the stumble What effect did it have on your driving?
Adam
