I was preparing to change over my front pads and rotors due to a sudden metal grinding noise with no indication from squealers. Soaked bolts with some pb blaster. Both bolts broke off at the head and my guess is they were over-torqued by a shop about 5 years ago. I've searched here with no results on the issue.
Compressed the piston enough to get the outer pad off for some more clearance. The sliders will not fully compress back into the calipers enough (feels like they are bottomed out?) to get more clearance as I would just have used a sawzall to cut the bolts but the issue now is I need enough length on the bolt left to be able to extract the remaining bolt in there and second my sawzall blade is too tall to fit in the cramped area.
Anyone have a bright idea that doesn't involved a stick of dynamite or a blowtorch??
