Figured you guys might get a laugh at a couple of these pics, some of these press setups have been real sketchy. Definitely a two man job, one guy to work the jack, another to hold and then catch the shaft assembly once the bearing pops off. One problem area, had to cut out the outer race on the inside of the input shaft, not enough room to get the jaws of the bearing puller in there, service manual does recommend a special tool for that go figure. Other than that it has gone smoothly. One piece of advice, make sure to order extra balls for the syncro assemblies. Those little things like to shoot across the garage while trying to reassemble. And make sure your press has plenty of clearance.
Anyways, I have 3 full days in on this project so far, hoping to get a 4th in this weekend. I've got all of the bearings replaced on the input, output, and countershaft. And the only bearing that looked/felt bad was the rear output tapered roller so I kind of feel like replacing every single bearing was overkill, oh well, piece of mind I suppose. Next steps: need to pull a couple outer races out of the housings, clean everything up, replace seals, and start reassembling. I imagine it will be a little tricky getting the endplay shimmed to spec. Oh, and gonna replace the rear main seal and clutch while everything is torn apart. Lots of fun...
