Dr. Ryan, That was great!
Why do you see 2 twisted pair and not 3? Does that diagram imply those 3 curcits are twisted together
What is a twisted pair? A pair as in phone line "pair" or a pair instead of a single wire and that pair go to a single pin, each wire in the pair carring part of the same load?
Where do you see the vss is used only on autos?
I see no guages in section 8w-40 nor do I see a curcit from the ecm to the speedometer. Am I visually impaired as a bat? It's pasta under the hood and pasta in the book only much straighter and at right angles.
I'll see if I can look up the "APPS ground line".
Many Thanks,
Fred
Twisted pair is a cable made up of 2 wires literally twisted along their length. Back when the telephone system was being developed, someone (Bell?) discovered that if he twisted the wires together it reduced signal noise. So twisted pair wire is normally used in sensitive instrumentation when it's important to get a low noise signal.
Twisted-shielded pair wire is the same as twisted pair, except there's a metallic shield that surrounds the pair of wires. That shield must be connected at one end to a ground, which provides a path for noise to follow. It's based on the idea of a Gaussian surface, which is way more than you wanted to know.
So in the diagram there are 3 wires shown, but all 3 are labeled "twisted pair". Which doesn't make any sense, since 3 twisted-pair cables would be 6 wires total. So I was thinking maybe they have 1 twisted-shielded pair with 1 wire carrying 5v, one wire carrying the speed signal, and the shield carrying the ground.
It's not explicitly stated that the VSS is only in automatic trucks, but it certainly seems to imply that. If you look at the service manual volume 1, page 8E-12, the VSS is discussed in the section about how the PCM works. Since M/T trucks don't have a PCM, I deduced that the VSS is probably an automatic-only item.
The reason you don't see gauges in section 8w-40 is that the gauges are not fed in a "traditional" way. Rather, they're fed on the PCI bus. Think of the PCI bus like the USB cables on your computer - they carry lots of data with only a couple wires. A multiplexer mixes the signals together from the various sensors in the engine, passes that along the PCI bus as a binary signal, and then a demultiplexer in the instrument cluster breaks the signal back into its component parts and distributes it to each gauge as appropriate.
You can see where the PCI bus connection occurs on page 8W-18-4 and 8W-40-5.
So, there is no speedometer wire going from the ECM to the speedometer. It's transmitted in computer code via the PCI bus.
At least, that's how I interpret the drawings. I'm certainly no electrical engineer. I keep waiting for someone to post "Ryan, you dunderhead, that's not the way it works at all!".
Ryan
