Details here: TDR Privileges
sorry, i searched but could not find what I'm looking for. i am looking for the box comparison that was posted a while back that showed the different boxes and rating of them. thanks for any help
I noticed that the DD UFM has two sets of data for all five power levels. Is this supposed to signify the difference in power levels when the UFM is installed on an ETC vs. an ETH? If so, it sure explains what many of us have seen when an ETH and an ETC dyno back to back on the same dyno with equivelant bombs.
If you already have gauges go TST if not a Blue Chip is handy for that reason also. I know my TST PM3 Comp version was a lot stronger than when it was only a PM3 before I got it upgraded. TST is honest in there claims and good people to deal with to in my opinion.
*note I am OVERFUELED at this point. The stock turbo will not clean up the black smoke on the upper levels. I WILL pick up many HP and a few TQ when I add AIR to the mix.
Are your numbers corrected flywheel numbers? If not, I want your secret to zero'ing out driveline power losses
Looks like you got +80hp/+167lb-ft with just the DDIII's. Do you know how the DDII's stack up in comparison?
dshawhan -- you sent the PM3 back to TST and they upgraded to "Comp"? Is their "comp" a standard upgrade, or is it specifically programmed for each truck, depending on intended use? What else is on your truck aside from PM3 comp?
Hope I'm not sounding like a broken record, guys, appreciate the info
Wade, what gear did you dyno in? I would expect a little more jam outta that truck... . and wait 'til you do a turbo... you've got about another 40hp hidden there.
