Recently I went to fill my air bags for towing. Because mine are aftermarket, I have two valve stems.
I decided to measure a side so that I knew what normal level was before I put air in them. I measured from ground up to the high point of the wheel flare. I decided to check the opposite side and it's a full inch difference.
I took it it in to the dealer today and they shimmed the front right box corner so it's the same distance when looking at the box line against the bottom of the rear window, however, when I measured from the ground to the top of the box at each rear corner, it's still 3/4" difference.
I asked the service manager "How can this be as the box floor sits directly on the frame rails"?
He scratched his head and said "I don't know!"
I told him, I'm concerned that if they shim the box on one side, with my 5th wheel hitch bolted through the box to the frame rails, it's going to cause a different issue.
I can't stand it when I hook up to my 5th wheel and look out my rear window and see the gap between the box and the 5er nose narrowing from right to left.
Am I being to anal about this?
Could the frame be twisted?
It's a brand new truck and built in a factory under controlled conditions!
