I'm in the process of replacing my fuel lines and I've got the bestest Trident marine grade hose I could get. When some of you replace the return line, are you talking about the braided section? Should I worry about it if its not currently leaking? I did get enough hose to replace everything, but I can't figure out why the return would be near the concern compared to the supply.
FYI- I got stranded in the Utah desert last weekend because of a 12" piece of fuel supply hose that the joker before me replaced with regular Napa fuel line. Of course, it rotted through, sucked air, and I was stuck. I cut the hose shorter, stretched the hard line, and made it home. If you don't want to replace the rubber section of your fuel line, put a 2 foot piece of 5/16" and 3/8" in yer toolbox, under your seat, or where ever. Its cheap, and you never know what it might be good for.
Thanks, JJ
Thanks, JJ
