2nd Gen Non-Engine/Transmission Brake/ABS light Code o500..Need help
OK I'm going insane here! My brake and ABS light keep flickering on, and sometimes just stays on. IT used to do it over bumps, now it doesn't matter. . Bumps will still set it off. The ABS system still seems to function normally. However, on Friday, the system activated when I belive it should not have. I was Slowly letting out the clutch, rolling up a small incline at a stop sign. I had to get back on the brakes and the ABS engaged. ALmost rolled into the road. The road was clean and dry.
A couple of weeks ago I changed out the sensor in the rear end. The top of the sensor did rotate a little, so it seemed broken. The Brake anbd ABS light did not come on for a couple of days. Then One afternoon, it started to illuminate with a vengence.
I OHMed out the front sensors and came up with 1922 and 1870 ohms. My 2000 Chasis diagnostics manual specs the sensors at 1000 - 1250 ohms, with a 30% correction factor for extreme heat or cold. It was about 35 Deg when I checked the sensors. Does anyone have the specs on the sensors for a 2002? Are they the same as the 2000 specs?
Any other ideas as to the possible causes? I have checked the wiring and grounds. the truck does not have a height-sensor in the rear.
i had a problem with mine . 98. 5 2500, with rw abs. changed the sensor , no fix checked wiring , found at left rear wheel , dc had clamped the harness to the rear sway bar, it chafed thru and was grounding out. have a look it might be the problem.
My ABS and brake light came one a couple of weeks ago so I did the same as you and ohmed the front sensors and came up with 1870 on one and 1865 on the other, so I replaced the one in the rear. Well that didn't fix it. Turns out it was the ABS controller. So I replaced that (second mortgage time) then the ABS light would just blink that’s when I found out the dealer must program it for the tire size and pinion factor. Basically, until you can read the codes from the ABS (as far as I know dealer only) you just can’t tell, as mine threw no OBDII codes.
James
