Brake and ABS light comeing on
Exhaust Manifold need replacing... suggestions?
Steering Box Adjustment
has any body had this problem? my ABS and Brake light in the daSH keep comeing on and then they go off and then they come back on, is there something wrong with my brakes or is there just a short somewhere?
Yup, mine did that too and also the cruise control was erratic and then finally quit altogether. Found out a small vacume line up by the firewall had a leak in it and finally got to the point where the light stayed on all the time and the cruise quit. Might be something to check on yours. Good luck
Had same problem also due to a small hole in vac. line. Wrapped it with tape and problem went away. Been just fine for several months now.
I recently had an ABS sensor on the rear axle replaced (under warranty). The ABS and BRAKE warning lights were on.
