GAmes
Some of you may remember that I had the failure lights and after buying a rear axle speed sensor needlessly I traced the fault to the brake controller for my RV. Imagine my disappointment that the new Prodigy controller produced the same failure after I hooked it up. I won't bore you with the details of troubleshooting but if your ABS light comes on with a brake controller installed and does not illume with it disconnected do not rush out to buy a new one.
With my trailer package I found that at the plug under the dash the hot wire should give you 12 volts, key on or off. The brake switch wire should give you 12 volts with the brake pedal depressed and of course the ground wire should be solid to ground. What you SHOULD NOT get is any continuity to ground thru the brake wire with the controller and trailer disconnected. It turns out that the connecter behind the left front tire in the little space behind the splash guard was FULL OF WATER!!! Live and learn and boost the economy by buying unneeded stuffOo.
