Truck is 1995, 5spd with about 95,000 miles
I am going to replace the brake booster (last hope). After new master cylinder and RWAL valve; front pads and rear shoes. Booster check valve checks out okay.
Local ******* (dealer) says brake booster is not available for 95 but if it was we want $240. 00 for it. Money is not a real problem, I just want the brakes to work. Local truck salvage yard says they have a booster that will work.
Question is: my service manual says use only a booster with the same number on the front cover (page # 5-18). I don't know what number the salvage yard has on the booster, (will find out tomorrow) but if they say it fits 95 ???? What difference will it make?
Original problem was/is. Motor off, pump up the brakes and they are solid!
Start the motor (while pushing down on the brake pedal) and the pedal slowly goes nearly to the floor.
My friends 97 does not do that!
Stomp on the brakes in a panic stop and it's Miller time or time to do CPR.
Any suggestions will be helpfull. Thanks, Tom/Idaho
