1995 3/4 ton 4x4 88,000 miles. Brakes were getting kinda spongy and sometimes the pedal would go clear to the floor during a panic stop. I replaced front pads and rear brake shoes, same problem. I looked in my 1995 service manual and followed the trouble shooting guide on page 5-7 master cyl/power booster test. After doing the test several times I replaced the booster check valve and the master cylinder, pump checked out okay. Bled the master cylinder as per instructions and same old thing happens.
I have noticed that when you pump the pedal (motor off)you can hear air escaping under the dash. After the pedal becomes hard and you start the truck the pedal will go straight to the floor. This does not happen on my friend's 96.
I am beginning to think the booster is the problem, but the dealer wants $240. 00 (American) and the closest one is in Denver which is 4 days out. I will probably order the booster, but was wondering if anyone here had any ideas.
Thanks in advance, Tom/Idaho
