2nd Gen Non-Engine/Transmission Brake Lights Problem
2nd Gen Non-Engine/Transmission Mag-Hytec diff cover for sale
2nd Gen Non-Engine/Transmission Steering wheel interchange
Well when I put on the brakes, Dside is fine Pside is dim & backup Lights come on at same time? for no reason, its like part of the power for the Pside Brake light is going to the backup lights. Truck is in drive. bulbs are good (any ideas)
It was the ground-wire in the bulb harness, where it splices from 2 wires (one from each bulb) into 1 going to the plug. easy fix once you find it Thanks
