Eric,
You kinda thru me there... . one minute we're doing brakes and the next we're doing pump's... ... man I thought I was trippin... .
Ok, once you've tweaked the pump to the point were you are seeing noticeable idle increase, your into the 'mortality' cycle of the pump. Now, this was posted some time ago, as a result of exactly that same question. The answer means you are now "working" the pump.
As far as idle you need to do one or two things...
One, if you can, use a 10mm deep 1/4" drive socket, a short extension like the kind used for attaching sockets to a screwdriver, you know what I mean?? It's a shorty, about 1 1/2" long over all.
Next reach in and slip it over the idle screw locknut, then use an open end wrench on the little extension. You may have to move/remove the little boost tube on the side of the pump to get a shot at it.
OR.....
You can resort to using a small chisel or screwdriver, reach down from the top and line the tool up with a locknut edge, then rap it...
I have seen some tuff locknuts come loose using this method BUT.....
It really boogers' up the locknut and you'll probably never get a socket on it in the future... . that's why I like to wrestle and cuss, mumble, stick out my tongue, and give it the evil eye, then use the socket method.
Last, if you've advanced your pump timing, you should mark the current position of the pump body, at the gear cover housing, then loosen the pump and rotate it down (away from the engine top). This will give you a bit more room to work.
Then all you need to do is rotate it back up, line up the marks, tighten it, and you're good to go...
Do you know about the breakover spring settings???
Bob.
