Power bleeders
Moon51;
A power bleeder is a pressurized bleed system that hooks up to your master cyclinder resevoir. You put brake fluid into the tank of the power bleeder, pressurize the tank with about 15 PSI, then crack your bleed valves one at a time to bleed the system. The pressure in the tank forces the fluid into the master cylinder resevoir and into your brake system once a bleed valve is opened. Never used one, so if I am wrong on my general explination, please, someone correct me here.
Another system uses vacuum to bleed the brakes. Don't know if this is classified as a "power bleeder", but it is also a one-man bleed system. You hook up a brake fluid drain hose to the bleed valve, and it sucks the fluid out. Some are manual, and some use compressed air that creates a vacuum in a catch bottle attached to the unit. Haven't used this one, either.
I bought Speed Bleeder bleed valves for my brakes. I am a bit old school with originally having to use the two-man concept for bleeding the brakes. With the speed bleeders, you open the valve the normal 1/4 turn, then go pump the brakes yourself without a helper! I love it! The company installed a ball and spring to make a one-way check valve inside their bleed valves. Plenty of ease for me.
I know it takes time to read though the threads. I have spent hours searching and sometimes still don't find what I am looking for. But there is a wealth of info and experiance I have learned from. I tend to get side-tracked a lot. Saving links and info I can use for other areas of my truck later. Anyways,... ... I am rambling a novel here. Let me know if I can help anymore. Trying to return the favors I have been give on this site. Tony.
Here are a few more links for bleeder info. You might want to search the these forums and then the web for a power bleed system.
http://www.griotsgarage.com/catalog. jsp?L1=L1_2000&L2=L2_2050&SKU=35701
http://www.speedbleeder.com/
http://www.egrbrakes.com/index-main.htm I bought their stainles/kevlar lines. They are nice!
http://www.stoptech.com/technical/ A lot of good general brake info under their "technical" link.
http://www.griotsgarage.com/catalog. jsp?L1=L1_2000&L2=L2_2050&SKU=85700 Another vacuum bleeder from Groits. Haven't looked for any power bleeder systems, so I don't have any info.
