Engine/Transmission (1994 - 1998) Brake rotors
Engine/Transmission (1998.5 - 2002) Smart Controller
No but I use a slotted and cross drilled rotor from NAPA and have had great luck with them paired with Wagner Thermo Quiet pads. 45k between pads and no rotors yet at 60k. Towing occaisionally up to 15k work great, lots of stopping power. Reasonably priced too. I think 135 a piece.
Sounds good but you,rs is 4X4 and has separate rotor and hubs, right? Mine is rotor-hub asy. Will check with NAPA.
I've installed the cross drilled/slotted rotors from NAPA as well, on the '97. Works the best to use an air chisel with a long punch to reach the studs. Doesn't hurt them at all.
Bmoeller - I think what hurt me was getting obvious gray-market wheel studs - they said Dorman but they couldn't have been. The shoulders on the shank stuck out much farther than the knurled ribs (we found out afterwards). A new set from another source could be driven in easily with a drift punch and a 3 lb hammer.
NAPA does not offer slotted rotor/hub assemblies which is what I need. Only separate rotors are offered. Still thinking of the ART units. Price seems pretty reasonable.
