Having some problems with new cross drilled/slotted front brake rotors. Have about 3k miles on them. Work fine until you really put a load on them, then they cause my disc pads to get so hot that they smoke
! Plus I'm getting brake fade which has never happened before. I've had this truck since '98, done many a brake job on it, never had these problems. Towing same equipment as always. Nothing has changed in my driving habits. I'm using Bendix Fleet MetLok pads, which I've used for many years. I'm thinking that there's not enough disc surface, due to holes and slots, for the pads to grab, so more braking pressure needs to be applied, causing more heat. Has anyone else had this problem with drilled and/or slotted rotors?
