WARNING!! If you plan on bleeding the brakes loosen the bleeders screws a day or two ahead of time not a lot just cracked em and tighten. (just to make sure that they do loosen) The reason I am telling you this is that there are several of us out there that have broken bleeder screws on the calipers. :{ I would hate for you to get everything off and ready to bleed only to find that the bleeder screws have broken because they were to tight from the factory.
Yes, this has always been a problem, especially with oldies. The little booties they put on the bleeders help a lot. I always use a bleeder wrench (a beefy 6 point box wrench meant for the job) or a real good 6 point wrench or socket. If there's no movement with moderate force, I get a propane torch and a small (1/4") worn out or sacrifical socket and small slugger to lightly hit on the tip of the bleeder. A lot of patience goes a long way here, usually with good results. I don't think you can do much heat damage to the caliper if you keep it around the screw/ boss.
Take a look at this
https://www.turbodieselregister.com/forums/showthread.php?t=138060&highlight=brakes
I broke mine with a 3 inch long wrench![]()
