I did a search of posts dealing with the brake warning light and read thru them all, but for the most part the gripes seemed to be that the warning light stayed on and the ABS light was on too.
I have different symptoms. Occasionally I will be driving along and the brake warning light will come on and a few seconds later it will fade away. I don't get the light during brake applications..... I had that going on a few months ago and found that my vacuum lines were weakened and collapsing. The only other thing I've noticed lately is that while doing slow speed maneuvering (more so while backing up) with light brake pedal application, I'm experiencing a mild "knocking" in the rear wheels..... I know it's coming from the rear brakes, not the differential.
Reading the manual, I understand the warning light is in circuit w/ the parking brake and the press. differential switch in the combination valve. I also see that the diesels have the low vacuum switch that is in the same circuit.
Since my fluid is fine, with no signs of leakage, and the vacuum lines from the vacuum pump to the power booster seem to be tight... ... ...
Do I have a vacuum leak in the power booster? Is that possible?
Do I have a bad low vacuum switch?
Do I have a bad combination valve?
