Brake woes again
Won't Start
New Grille
Check the floor of the truck, under the floor mats by the brake pedal. When master cylinders go bad, they can leak into the truck, with the insulation soaking up ALOT of fluid before it becomes apparent. If you're losing fluid and can't figure out where it's going, this is likely the culprit.
