I'm on my fifth CTD. Not because they are bad either!
After five trucks in fifteen years I can't say that the break in resulted in a significant improvement in fuel economy. Maybe one mile per gallon at most.
They importance in break in comes from achieving a good ring seal. To achieve this you need to work the engine hard to get the internal cylinder pressures up. This forces the rings more tightly against the cylinder wall. In this case you actually want to wear the rings into the cylinder. It produces a nice tight seal and helps with oil consumption as well as reducing crankcase pressure. I suppose taking it a bit easy the first few hundred miles is ok because that is when the most severe abrasion (read break in) is occuring. You get some extra heat then, and it's possible if you roar up hearbreak hill with 15K in tow at 3,000 RPM and ten miles on the odometer you might aneal the rings.
Anyway, After a couple of hundred miles hook up to a good load, 10K or so, and run her pretty hard. It's good for the engine.
I've never had enough oil come out of the breather tube to leave a spot in the driveway. Even with 100K plus on the odometer. That's because the engine was broken in right. I've seen some guys that complain about drips from the breather. In many cases it may be the result of improper break in. Most of the break in will happen in the first thousand miles or so, but continues for a few thousand miles. The use of synthetic is the kiss of death during break in. I'm not a big fan of them for cost reasons, but for certain don't use them during the first ten thousand miles.
