Breeze Clamp Products
best deal on PE 3 level??
NAPA filter mount / heat shield
Chuck,
I sent you a spring loaded t-bolt clamp. The installation torque on this type is between 50-60 inch-lbs.
The factory clamps install around 70. This is due the locking collar on the factory clamps. It requires 10 inch lbs. to turn before a load is applied. The heavy duty spring t-bolt I sent you uses spring load to keep the nut from loosening.
Good Luck,
Ken
