Hello,
I thought I would pick the great minds of TDR first with this issue.
I went to use my 60in trail mower, with B&S 12. 5hp vertical shaft model 289707, a few weeks ago with it in the 90s out and after I warmed up the engine for a couple minutes I ran into this problem.
It will run decent/smooth with the choke on and if it is on full throttle it will be rough (the governor keeps moving back and forth) and it pops/backfires out the exhaust. Anything less than full throttle or if I try to engage the electric pto it just slowly dies out.
I thought it was fuel related so I tried a new fuel filter and I thought the problem had been fixed because I useed the unit for 4 hours after that without issue.
I went to mow today and used the unit for 2 hours and then ran into the same problem. I tried running without the fuel filter. I tried taking the carb apart and cleaning everything inside, but everything looks good inside.
So I just started playing around with the throttle and choke and it seemed to clear up for a few minutes so I tried to continue mowing but the problem kept coming back. I continued to keep trying to play with the choke and throttle and that lasted for a little while but then I just got too frustrated.
So now I am stumped as to whether this I have an intermitten fuel problem or if this might be some kind of electrical/ignition problem?:{
Anyone have any ideas or know if a good LAWN MOWER FORUM that I may be able to try? I would appreicate all the help I can get.
Thanks,
Nate
Thanks,
Nate
