2nd Gen Non-Engine/Transmission Brite Box- Help!
Engine/Transmission (1998.5 - 2002) J-Hook question
Installed new brite box- now I have no fog lights and the relay buzzes when I turn them on. Fuses are good. I took the brite box off and it still does it. Help!
Thanks, Ben
Installed new brite box- now I have no fog lights and the relay buzzes when I turn them on. Fuses are good. I took the brite box off and it still does it. . .
I assume the relay you mentioned is the fog lamp relay in the Power Distribution Center.
For starters. perform the fogs-on-with-high-beams modofication shown at the very bottom of this page: http://dodgeram.org/tech/mods/electric/headlight.htm. A paperclip will make a quick & dirty jumper.
From the factory, the fog lamp relay is used an interlock, opening when high-beams are selected. The jumper in the linked modification mimics the closed relay that is present when low-beams are on and eliminates the electrical path through the coil of the relay (possibly the cause of your problem).
