Broke the leadwire!
Interesting sleeper...
A Pillar Tweeter Removal?????
So my EGT was giving me erratic readings (wouldn't break 400 Deg) so I pulled it out to check the connections and one side of the leadwire broke at the ring terminal.
Can I just crimp it to a new ring terminal or should I replace the whole wire?
Mark Callahan
1998. 5 3500 4x4 24V 5spd, Geno's Muffler Kit, Chrome exhaust, Western Hauler Headache Rack, Chrome Rocker Panels, A-Pillar Mounted Boost ,EGT and Oil Temp Gauges, Rhino Linings sprayed in bed liner , CATZ lights, No Turbo Silencer Ring (Yeah Baby!)
You can recrimp it, that small length will not make a difference. bg
White 99 3500, QC, 3:55, auto. most options except leather, Line-X bed liner, fiberglass running boards Rancho 9000s, bug shield and window vents, black vented 5th wheel tailgate, 110 gal. aux. fuel tank.
Contrary to popular belief, the length of the pyro wire does not make any difference. It would if the run was like 200 feet, but a few inches will make no difference. Go ahead an splice it.
Its ok to splice but you want to be sure the splice is very low resistance, preferably soldered. If you cant solder it, twist the wires together then crimp a butt connector over it. Just make sure the copper is touching and it will be good as new. High resistance will affect the accuracy.
guys-
the leadwire broke right at the ring terminal so now I have a ring terminal and a leadwire.
I suppose if I can crimp in a new connection then I can just crimp in a new ring connector. I'll try it and see what happens.
Mark Callahan
