Just my opinion, I'm doubting it very much, there's doubtfully enough oil in the intercooler to cause a runaway. May be fogging for mosquitoes, but doubt a runaway. I guess I'll find out later today.Just asking, theoretically.
If the oil flow to the turbo is plugged and the turbo won't make boost, will it run away? I don't think it would make enough vacuum while running to suck enough residual oil out of the intake system to actually run away. Unless I'm wrong, an oil caused runaway is from a constant supply of oil and high boost pressure in the intake.
Before I go anywhere, filling it full, see just how much it takes, then start n listen. When it dropped, it was at the middle of the oil pressure, normal, and as I pulled over to stop, it dropped quickly and warning came on as I was turning off key. I'll find out later today. As for N/A, I'm hoping it's no worse than my old 6.2 Chevy.Since you got low pressure indications I’d check for problems caused by low oil pressure. The dash wont tell you oil pressure is low until it’s been less than 6 psi for 30 seconds.
You’ll definitely be limping hope, these aren’t good NA motors.
...but I hear a mouse cough if it comes to my truck, real annoying ability.
Where'd you work on Apaches? I started 67V/Y n reclassed 67S n then 67R. 23 yrs total. Our since '06.
