Engine/Transmission (1994 - 1998) Broken Barrel....
Engine/Transmission (1994 - 1998) PDR intercooler boots
2nd Gen Non-Engine/Transmission Looking for performance shop in NW Illinois
So has anyone broken a barrel in half on a p-pump. I have never seen this happen or heard of it happening (until it happened to me). I was out playing around and then all of a sudden I was running on 5 cylinders. I took the injector line and delivery valve holder off and then went to loosen up the barrel hold down nuts. Once I loosened the nut the top of the barrel moved around. It ended up snapping in half right under the casing. Any ideas why?
i have seen this when water past through the filter water has no lub or compression going up through the injector and ends up in the p-pump hot gasses!
kurt fuel injection tech
diesel specialists inc.
