Coming back to Wyoming from PA with the slide in on the outside temperature got up to 93 degrees in Iowa.
At 65 mph on the Cruise Control the transmission gauge was at 175 degrees and the engine was running at 190 degrees. A little High.
I thought now would be a good time to remove the bug screen and see if it resticts the air very much.
I stopped at the next road side rest and removed the aluminum door screen I had in front of the radiator and left it off the rest of the day.
The temperatures did not drop one bit. They ran exactly the same as with it on, so I will run with my bug screen on always!!!
