Buick engine problem, HELP!!!
REAL Football season starts Saturday
Not my time, I guess...
1991 buick century 3. 3 liter v6 auto matic trans. 56,ooo miles original owner engine misses at idle and through running speed and has a bad exhaust odor , smell like rotten eggs. I have replaced the plugs the wires and the oxygen sensor along with the catalytic converter. I am unable to locate an egr valve. Does it haveone, if so where is it located? Also, I unplugged each injector and found one with no noticable engine change.
You need to check the compression on the cylinder that shows no change when you unplug the injector, sounds like a bad valve and raw fuel going to the converter causing the odor. To correctly do a compression check you need to remove all the plugs and test all cylinders one at a time with the throttle valve partially open and energizing the starter with a remote switch so the injectors won't put more fuel in the cylinders. The pressure for all cylinders should be within 15% of each other. If you don't have acces to a compression gauge, remove iginition wire from the distrubitor so engine can't start and turn engine over a couple of revolutions. You can usually tell by the sound of the starter if you have a weak cylinder. bg
[This message has been edited by B. G. Smith (edited 02-04-2001). ]
