It's just sad that a 40-year-old 2-stroke Detroit Diesel 6-71 or 6V-53 (or any variation thereof) can have a real engine brake...
Nick - how are the DOHC Cummins engines (ISX, etc. ) setup for engine brakes? My exposure to these engines is embarrassingly low.
Matt
matt - the ISX has 2 camshafts, one to actuate the injector rockers, which would be on the driver's side of the engine, and the second cam, drives the intake rocker, the exhaust rocker, and the exhaust brake rocker, on the passenger side of the engine. yes, there are 4 rockers total, im trying to rember how the exhaust brake rocker works, it was explained to me once, if i remeber correctly, there is actually a lobe that drives the rocker, when a tech a cummins runs, or "adjusts" the overhead on the isx, they set the injector preload, set lash on the intake, and exhaust valve, and on the exhaust brake rocker, ther are 2 different lash setting. the first one uses the adjusting screw to find the lash between the cross head guide pin, and the engine brake lever actuator piston. once that is set, we have to simply check the running clearance, that is crucial, if the running clearance bewtween he two rollers is not right, there can be severe engine damage. so basically the rocker is spring loaded, this keeps the rollers from coming in contact with each other, when the brake switch is flipped, the solenoid pushes down on the rocker assy, making contact with the camshaft and the rocker roller, this happens while the exhaust valve is coming backup obviously, thus the cam lobe is at the highest point of lift, causing the valve to stay open for the duration of the lift of the lobe. this causes the engine braking, and when the solenoid is off, the clearance betweenthe rollers is acheived. im pretty sure that is the way the interbrake works, im going to talk to my buddy at work tommorw, who knows all there is to know about the isx, and make sure i described the function correctly.
wes
