Well, here's something I would like to revisit.
I think there are a lot of guys like me who REALLY dislike an oiled filter element. Thus, we are forced to run the BHAF or stock filter.
But, as HP increases, the BHAF begins to get out of its league, or at least that's what I've been led to believe. I have no idea at what HP that BHAF starts to lose HP relative to other intakes, but the DD Jammer 2 turbo thread mentioned that the BHAF was down on HP relative to the AFEs at lower HP levels than many of us would like to run.
So how can we get the high flow we want with the high filtration?
One option is to look at big rig air filters. There's the Farr Ecolite that Mallinson has made famous for its 1500CFM flow rating (at 8" water!). But it's next to impossible to package this on a Dodge pickup, as the dimensions are much too large.
Enter the Donaldson PowerCore. This is the way I am trying to head
Why PowerCore? Well, packaging is much smaller. Dust holding is over TWICE what a conventional filter would hold. It's DRY. It filters at a 99. 99% efficiency rate. This compares the the top-rated AC filter from the air filter shootout that's been much-discussed on here and other diesel pickup boards-- only it flows a LOT more.
Donaldson is a VERY respected name in filtration.
So, I get to digging, and find a possible candidate:http://www.donaldson.com/en/engine/support/datalibrary/034267.pdf
Note that the flyer linked above lists applications that flow up to 1000CFM!! This is the model PSD12, I believe.
So, I'm in the process of getting specifics from Donaldson as far as packaging dimensions and outlet sizes. The flow is there, and so is the filtration.
I've examined a round POwerCore filter on a Freighliner M2 high hp (Cat C7) and it was about the size of a BHAF, but it had a 10" outlet and needed special adaptation to work on the M2 that made it a no-go for a CTD. Maybe someone else could make it work.
Anyway, I will post updates once I get more specifics on this new possibility. We can make the BHAF better!!
Justin
Justin
