Kirk,
Not much time on it yet, about 1500 miles. Time will tell. The pre & post filter psi's are holding just fine though, 13 - 12 pre, 12 - 10 post.
I have done some wot's, pulled my 5er where I left it in wot for 20 seconds (32#, 1200*), min post filter is 10, min pre filter is 12.
Before when it shifted from 3rd to OD I would see a psi spike post filter to about 16 - 20 for a second or two as the psi in the vp was high and the rpm dropped abruptly as the shift happened. Doesn't happen now, which I think is a good thing.
The fuel psi's are totally stable. My intent is to keep the lp turning smoothly, with no more than 13 psi head pressure, the check valve ball stay fully seated. Seems to be working.
If and when the lp starts to fail and the motor looses power I can just readjust the bypass, probably will just change the lp. Should be interesting to see how long the lp will go humming along. I bet for a long time.
Another part of the puzzle is "stiff fuel" or debris stressing the lp motor nylon sleeve that connects the lp motor to the pump. I have a RACOR 690 10 micron water seperator filter with the fuel heater and use Stanadyne Performance Formula for that eventuality. The lp should never see anything but treated fuel of the right temperature with a very low pour point and very high lubricity. Keeps the pump rotor vanes well lubricated so they can fully use the centrifugal force to stay seated against the pump chamber walls and maintain pressure.
The Stanadyne also coats the tight tolerance VP parts so when you have had high demands on the VP and good flow for cooling and lubricity, then drop the demand to idle with little flow and little lubricity there is more of an anti friction coating on the internals to the VP than just the fuel. At least my take on it. I got this from the TDR chapter meetings at VP pump rebuilders. Also the RACOR makes sure NO water EVER gets to the VP.
We had meetings at pump rebuilders and their answer to high pressure pump failures was the same over and over, water damage & lack of lubrication. The RACOR blocks water. I think the OEM fuel filter does not actually block water, but tries to shed water. With 2 water filters my chances are higher that I can get ALL the water out. The Stanadyne helps with the lubricity.
Of course move the lp to the tank with AN-6 or larger lines and NO right angle fittings, NO banjos, ONLY full flow smooth fittings.
Unique, nope. Many have done the same thing. The FASS "takes the air out of the fuel". Not sure how to do that. Might not be able to do that. Might be of consequence, might not be.
Time will tell,
Bob Weis
