RustyJC said:Justin,
I've towed heavy 5vers with both (47RE and NV5600). The gaps between gears are way too wide in the 47RE. With the automatic, I always found myself either running bunches of revs in a lower gear or unable to hold speed in the next higher gear.
It's much nicer having 6 more closely-spaced ratios to work with between 0 and 70 MPH.
The 6-speed Aisin automatic may just cure this problem and make me a slushbox convert on the next truck!
Rusty
Rusty, was this on your previous V-10 truck? I ask because the superior power of the CTD may offset the absence of ideal gearing, esp. wrt gear splits...
Also, would it make a difference if it was a 4. 10 axle vs. a shorter axle? Without crunching the numbers, it would appears that the axle ratio only affects VEHICLE SPEED, and has no effect on the INTERVAL between gears...
Let me know.
