Patriot!
Do You have a Guidegun with the microgroove rifling or the new version of the ballard rifling? The microgrooves don't seem to grip the lead bullets to well at the higher velocities.
KBurgoyne,
In todays economy with tools widely available, I don't see any "kits" available other than what Lyman has to offer. Lee has the cheapest lead furnace. I have a Lyman and 2 lee 20#r's. Lead dippers are applicable for some moulds and not so good for others. The bottom pour furnace works best IMHO for a heavily grooved bullets. The hydraulic pressure pushes the molten lead into the tiniest grooves of a mould block set that is up to casting temperature. They also have the volume for gang moulds! I have two; a Hensley and Gibbs 6 cavity .44 mould that throws 250 gr Keith type bullets. LOTS OF LEAD REQUIRED each pour. A H&G .45/ 225 Gr. 4 cavity mould that also require a significant quantity of lead.
Getting moulds to release consistently has been a problem at one time or another. An eccentric cavity can lock the bullet into one side.
For a concentric cavity, smoking the cavity with a wooden match creates a carbon layer that acts as a barrier between the lead and the hot mould block, preventing soldiering. That is "old school" stuff. Now, there is commercial mould release, available! How well it works?? I have no clue!!
I use Beeswax as a flux. You can use commercial stuff, if ya like. Beeswax is cheap and non toxic. It smokes a lot but I usually light it off before stirring the pot while the flames are still burning.
Just be clean about your self and work area. Don't do this where you can track debris into your living quarters, ESPECIALLY if there are CHILDREN around.
Bullet lubricants are really critical, especially at the higher velocities. LBT Blue and Lyman Moly lube are some of the best.
If Ya shoot blackpowder cartridge rifles or a rifle musket with minie balls. A mix of 50%/50% beeswax and petroleum jelly is an outstanding home made lube and very similar to the original lubricants! Combine it in a double boiler and mix thoroughly. Pour into a luber sizer or set the bullets into a tin pan (.58 Minies ) base down, pour lube into the pan covering all grooves. Let it harden. Use a deprimed 28 Gauge plastic shot shell cut just a little longer than the length of the minie, inside dimension. Cut a dowel that fits through the primer hole. (You can drill the hole larger and make an ejector pin out of brass or steel.). Slip the case mouth over the minie and press through the lube with a series of twists until ya hit the bottom of the pan. Pull it free and push out the lubed bullet with the ejector pin. WORKS GREAT! That lube keeps the powder fouling soft as long as the humidity levels are reasonable. In the dry West, ya may need to use a blow tube, just to get some moisture into the dirty bore to keep the black powder fouling manageable. Bt that is another bunny trail =)!
If Ya can lay out your goals in more detail, I may be able to make some starter tooling recommendations.
GregH
