First , I am a controls and electronics engineer, so I believe I know the thinking and practicality behind the design and mods, but I'm not a Dieselier, yet
Yes, the ECM has a limiter, it appears to de-fuel beginning at just below 3200, and I have heard that it doesn't come apart until it reaches 4200, so I guess its safe. I've seen 3600
The flare is caused by the Rail Pressure still being high, and the ECM not completely ever not firing the injectors less than a certain duration (cooling?), when you remove the load, push in the clutch, the pressure bleeds down through the return line and the injector orifice and is burned, the engine speed naturally rises. It is worse when getting on it with the EZ on 4 I think, and not good for the clutch either.
I think the 'wasted' fuel would amount to microliters and is insignifigant and the process to shear the fuel would be overly complex for an irrelevant result.
DM
DM
