Tried to download my Bully Dog Power pup from extreme setting back to stock today, and everything was going fine until the end where it started the initialization 8,7,6,5,4,3,2, and then 1 and then it just stopped at that point? It usually only takes another second and it's done. waited 5 minutes still stuck on #1. Unplugged and got the "erased" message you need to recover mode, disconnect batteries for two minutes, reconnect, turn key back to on and then press "Y". OK, the thing starts to download again, 0-100%, starts the initialization sequence again and gets stuck on #1 again?
Tried this two more times and nothing!!! Has anybody had this problem before? Can't call BD, their closed. Do you think I need to take to dealer for a re-flash? :{ :{ If I need to take to a dealer for a re-flash, is the Power-pup screwed-up? Does the power-pup need to be re-flashed also?
