bullydog products
auto to manual swap
RASP Mechanical pusher pump!?!
ive got a 00 6sp nonHO w/ a 70hp torque dog and 80hp bullybooster injectors
with a hybrid hx40/35 and i can only squeeze out 30 psi of boost. My TST
powermax could get 42 psi w/ my stock 35. Should i be getting more or not
I know the box is good cause its only 2 months old is there something wrong w/ my truck. intercooler boots seem to be in good condition
Welcome to the TDR! I would definitely keep an eye on the boots. Just a touch loose and they could leak. I don't know what else to tell you, I am not that good at comparing the TST and the module for boost numbers, someone will help I am sure!
Nick
My TST box and Dodgezilla 35/40 hybrid will easilly put out 46lbs boost. B4 the mach 2's about 44lbs. With the stock HY35 I would get 34lbs The Powermax is a real beast, makes a big big difference.
