You are correct the bump you feel is from the fuel tank and if you go on fritz's Dodge site you will find a tsb for your problem you must have a 2000 s/b quad cab I think that is the only effected model the dealer will replace your tank for you if you are under 36k miles just print the tsb off the site and take it with you. You can find the site in the links section.
