Engine oil doesn't burn worth a darn. It is too heavy to vaporize well. It is also too thick to be compatible with the tight clearances in today's engines. When you add the junk including soot and wear metals in used oil, it makes no sense. You drained out the used oil because it was too junky for the five thousandths bearing and piston clearances in the short block. Then you put it through parts with twenty-five millionths of an inch clearance. Not good. I just helped replace injectors in a 2005 Turbo Diesel engine that had seen used oil for a short while. All the injectors tips were gummed up, and if you pulled the head, the rings would be in just as bad a shape.
