Just a quick FYI on burning waste oil. Immediately after pouring about a gallon of recently drained used Delo 400 15/40 into my main fuel tank, my lift pump pressure became very erratic, frequently not pumping any fuel at all - thank God for the pusher being in there to take up the slack!
Indications are that the stock LP is cavitating with the added used oil - pressure quickly returns to normal if I really hit the throttle under load, and the output of the pusher pump causes the LP to regain normal function.
The Carter pusher thus far seems unaffected, possibly due to it's lower operating pressure. I've changed the inline Frantz TP cartridge, and noted it was quite dark with the accumulated soot contained in the used oil - but normal LP function was not improved upon changing to a new TP cartridge.
Upon topping of the tank with about 10 gallons of fresh undiluted fuel, LP function is greatly improved - my particular LP just doesn't much appreciate the use of used engine oil mixed with diesel fuel - might not have been as severe if I hadn't used a 30 to 1 mix ratio...
Just keep this in mind if you have a similar plan on your horizon - and this sorta makes me wonder what might happen in relatively high doses of various bio fuels...
YMMV!
YMMV!
