Well... . That's the best way I could find to refill the radiator after changing coolant!!!
Is there a better way to make sure the system is full and all the air has been purged out of the system...
I think the "Overflow" container plays an important role in this...
I found that if I get the engine hot. . then CAREFULLY crack the radiator cap. . that the trapped air will be pushed into the resevoir...
Then when the cap is re-tightened and the radiator cools it will "Suck" coolant from the resivoir to top off the level. .
I repeated this 3-4 times already and I'm still getting air to blow out, into the resevoir
I've gotten almost another GALLON to go into the radiator after refilling with fresh coolant from the radiator cap side...
When the block and radiator are drained there are little nooks and crannies that trap air in the system...
I first noticed that I was running a little hot on the way to work after changing coolant.
Then I noticed that the overflow tank had no coolant in the passageway that goes into the radiator...
When I cracked the radiator cap I saw that the level of coolant was low...
(it was full when I refilled)
After the coolant circulated , the trapped air must have found it's way to the highest point in the radiator
I just changed oil. . and there was no trace of water in it...
Also the tailpipe shows nothing... so the coolant isn't leaking places it's not supposed to be. .
Is the Burping Method the best for "topping off" the coolant level???
Larry
Larry
