I like how you have the 3rd gen side mirrors on there.(well, 01 or 02-ish and later)
They are actually 02-and down mirrors. They are almost a direct bolt on with only a few minor mods to make them work but everyone asks how I did it.
coming from a fabricator i know how hard it is to make that piece in the brake, ive made my fair share of them. the fab work on the twins is awsome. some day soon i will be building my own set and tig welding everythingonce again top notch work
The Fat Kid
Andy
Lookin' good...
Now, I'm just thinking out loud so take no offense, but the intake tubing seems to be pretty long coming off the head with no rubber boot anywhere? With the vibration levels of the mighty cummins, thats alot of leverage on the welds at the head or the gasket under the intake plate. Does the tube run solid all the way to the charger on the other side? If so, then it's probably not so much an issue I guess as the whole assembly would move with the engine.
I like the idea of the pop off valves prior to the shutoff valve (haven't seen that before), that would help the spinny things last longer.
I would think about putting a bracket/brace(rubber mounted of course) between the boot at the turbo and add another boot at the top between the split and the last 90* Maybe not so much for vibration, though it would help, but incase you needed to work on you truck you would have the option to remove a section instead of the whole deal. Other than than it looks great! Tha brace I'm thinking about might look like a swaybar mount? Or those little tabs to hold brake lines and such with... .
Where did you get your air shutoff device from? Pics? Price?
Thanks!
