I have a 2004 Colorado made by Dutchman. It's been a great mid-level camper costing about $32,000 new. No problems except for loosing one tire. It was covered by warranty. It pulls real nice, I can leave things on the counters unless I have to do a panic stop. I pull an 2000# ATV trailer behind it. The fit and finish is great. Good quality appliances. Solid interior doors. This is my fifth camper.
My first one was a 1978 Nuwa/Hitchhiker class C with 115,000 miles. It was great and I put another 30,000 miles on it. I had a 2001 Fleetwood Wilderness prior to the Colorado, and it total junk. Traded it off as I wondered if it was going to stay together, and it WAS falling apart. I friend of mine bought a new Wilderness in 2004 the same year as my Colorado, and there is no comparison in quality when compared to the Colorado.
If I had the cash, I'd consider a King of the Road. Jayco makes a nice unit. A nice HD unit is a Kit and I almost bought one of those twice. Avoid the Four seasons and low and mid level Fleetwoods. When purchasing an aluminum framed unit, insist upon solid wall construction meaning foam insulation, not fiberglass. The fiberglass blankets fall down inside the walls between the studs on aluminum framed units.
I prefer the fiberglass exterior walls with aluminum studs, Styrofoam insulation, all laminated to an interior wall, rubber roof with good thick plywood. Look for round radius doors and windows. In slide outs, make sure that if the wheel well and slide out are shared, make sure there is a REALLY GOOD double seal between the slide and the frame to prevent road water spray from entering the exterior of the camper. If you’ve done any construction yourself, and know how to build something with quality, it's easy to use this to compare campers. Crawl inside, out, through and underneath of all the brands, you'll see the difference between them. You can get a great deal at a camper show, and often times there are factory rep’s at the shows. Don’t be nervous about crawling under the campers at the show. Dealer cost on a typical unit is 50% to 60% of full price sticker. WHEW! You can see mine at
www.hookusup.com/colorado
Good Luck!!
