Diesel Thunder said:
So, I gather from the posts that with the unit I am considering (Amsoil Bypass BMK-11), there should be no oil pressure, flow, or volume issues?
As I understand it, the bypass setup has a restrictor to prevent pressure/flow loss to the engine?
Or, as good insurance, should a check valve be installed that would prevent the oil accessing the bypass filter when pressures are say 25 psi or below?
This is a very interesting concept on oil filtration. As someone mentioned earlier though, is it worth the trouble and complexity?
I think it may be. But then again, I have seen diesels disassembled that still looked excellent as far as wear on the mains and crosshatching in the cylinders with 200-300 thousand miles. Diesels that had regular oil changes with no bypass filtration.
However, as the recent TDR issue explained, the new oils that are going to be introduced (API CJ-4?) mean there could be wear issues that a bypass setup may be able to help minimize.
Diesel Thunder.
You might look at a by-pass filter as an addition to your engine’s security system. Your regular oil filter passes the
full flow of oil from the pump and removes particles bigger than about
20 to 30 microns.
Left in the oil, particles smaller than this size can contribute to ring, liner and bearing wear. These same particles can also contribute to engine deposits, which can hurt engine performance and induce oil consumption.
If the regular “full-flow” filter were designed to filter smaller particles, there would be a risk of
insufficient oil flow through the engine as particles accumulated in the filtering media of the full-flow filter element. In fact, regular filters come equipped with a “relief” valve, sometimes called a by-pass, to allow some of the oil to by-pass them completely. These valves insure the proper flow of oil is maintained to protect the engine, even if the filter media accumulates enough material to cause excessive pressure drop across the filter, or the oil is too
thick to pass through it fast enough.
By-pass filters are an addition to the regular oil filter. They take only a portion of the oil pump’s flow, and can therefore be more efficient in removing even smaller particles than 5 microns. Eventually, all of the oil gets circulated through the by-pass element. Removing particles smaller than 20 microns is another step in reducing the risk of engine wear, and can also help in reducing risk of oil viscosity increase.
A side benefit of a by-pass filter is that it usually increases the amount of oil necessary to fill the engine oil system. More oil means contaminants are less concentrated and likely to cause harm to the engine. More oil also means more additives are available to neutralize contaminants and protect vital engine parts.
By-pass oil filters can add to your line of defense against engine wear and deposits, helping maintain engine performance and long engine life. When it comes to providing you with security for your engine, a high quality filtering system goes along way. But then so does high quality synthetic engine oil like Amsoil.
Here is a link that shows some installations on the CTD trucks. There is also a drawing of a by-pass filtering system, so you can visualize how it works. The restrictor, that has been talked about is in the return side of the by-pass mount, and is very small, so it will reduce the "flow" of oil going through it, as well as keep pressure behind it, so your oil pressure will not drop. The oil that is returned from the by-pass element,
is not under any pressure, and therfore will just flow out the end of the line.
Hope this helps.
http://www.1gr8oil.com/singlebypass.html
Wayne
amsoilman
