Cab Roof Clearance Lights
Will an Injection pump and turbo from 90 fit 91.5?
Speedo gear tooth count
I did not get stock numbers for the Hella Clearance Lights but, A&M lighting
on Ebay has them... . I just bought a set from them... I will post the
stock numbers and try and find other sources for the lights when I get
them.
from the "what its worth file", i feel the best option for cab lighting for appearance, durability and just plain "moparismo", is to use the fender indicator lamps that chryco used on a zillion rides for years... the lens is amber, it uses a 194 push in, and other than a bit of searching to find a set, and a bit of wiring, they would look great. i havent installed mine yet as i will do the body and paint first, but i had installed them in the normal turn signal fender locations as i cant see the dash indicators when i have the steering column tilted where i like it... anyway, they are much smaller, but just as effective... cheers d
I just got my cab clearance lights in today. They are pretty sharp looking. They came in an unmarked box but, I did manage to pull a couple of numbers off of them. on the front in the amber lens "Hella SAE P2 PC 84 DT Mexico" I was able to remove the lens from the body and on the back there looked to be two stock numbers "3738011 3738012". There were no marks on the
Chrome body of the light. :eek:
