Just an update on my heater issue - still not solved -might help someone else also having this problem.
I replaced the Control unit and still had no heat. Pulled the water pump to see if the impeller was spinning on the shaft - it wasn't, couldn't budge it. I was at my wits end, and went to a Dealer to have the HVAC doors re-calibrated with the DRBIII Scan Tool, since this was the only thing I had not done. They tested the whole system and the actuator motors too. Nice thing is, they only charged me a $30 diagnostic fee!
Dealer seems to think the heater core is the issue. They are saying it is possible that the heater core has good flow, but several of the channels could be blocked. In other words - the heater core is like a radiator in design and I could have good flow because the water entering (when flushing or during normal operation) maybe be able to pass thru a few clear channels, unrestricted, near the beginning of the core and exit, which would look like a good flowing heater core, but not allow a good radiation of heat because it's not flowing thru the whole heater core. One thing I did find out is that the passenger side is blowing "warmer" air than the drivers side, even though I cut out the divider in the air box. This does lend some truth to there theory of a partially blocked heater core, thinking that by the time the air makes it to the drivers side vents it has cooled back to ambient temp, while the path to exit the passenger vents may be shorter and a small amount of heat can be felt. Or that the passenger side of the heater core actually does have some channels that the hot water is flowing thru, but the drivers side has none.
The tech's suggestion was that I remove the heater core hoses and with the heater core filled with water, blow air (at about 25-30 psi) through the heater core, both forwards and backwards several times. Also, to hold a shop rag over the discharging hose to capture any particulates (if any) to see if I am getting any thing out. He also said I could also attempt to use some kind of chemical to assist in breaking things loose, by filling the core with it and letting it sit for 30 minutes then blowing out with air again, both forward & backwards. He said that he has done this a few times before and was successful.
If that doesn't work, then it looks like a heater core for me.
