Hello TDR, new member here in need of quick advice. My 2003,quad cab, three-quarter ton purchased one month ago is having cam gear problems. Mileage is 65,000,automatic,two wheel drive. Last week the dealer where I purchased it from replaced the cam gear stating it had excessive run-out. This also was the cause to replace the injector pump gear. For three days everything was fine, now the same noise is BACK !!!!! I'm taking the truck back tomorrow to talk to the service manager about this problem. My thoughts on the issue are the run-out now must be in the cam itself,or excessivly worn cam bearings to cause the failure again so quickly. Any and all advice will be greatly appreciated.
Thank you. RMedlin TDR# 5071174
