I’m in the process of gathering parts to fix my KDP damage (timing cover, etc).
A question for those who has done it before: To replace the timing cover, is it easier to pull the gear off of the camshaft or is it easier to remove the camshaft? Any comments either way?
Also, for a stock truck are there any good replacement camshafts out there. I’m not looking for wild, but will be going 370 injectors, a #10 plate, etc. , probably after I get this fixed. If I gotta take the camshaft out, I would like to bump it up a notch or so.
It looks like this would be a great time to check timing and adjust valves. Any other modifications you see would be easy to do when doing a timing cover?
Thank you,
Bud
Thank you,
Bud
