Vaughn MacKenzie
I thought someone posted instructions on swapping cams once, but I'm thinking about tackling this except I don't have a shop manual.
Basically I'm thinking it's remove radiator, fan & shroud, trans cooler, swing AC condensor out of the way, remove timing cover, remove valve covers, remove long head bolts & valve rocker stands, pull pushrods to install dowel rods to hold up tappets. Remove lift pump, remove cam retaining bolts, swap cam.
Anything I'm missing? I've seen posts about the dowel rod thing but can't quite picture how they "grab" onto the tappets & hold them in place. Is this a safe way to make sure a tappet isn't going to fall out?
Also, I don't need to lift the motor or anything for the cam to clear the radiator crossmember? Lastly, I shouldn't need new tappets right (that's probably up for debate)? Engine has 180,000 miles on it.
Vaughn
Vaughn
